BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
2000 Explorer XLT 2WD 4.0L SOHC JOB1 5-Speed Automatic O/D 5R55E
Between 40-45 MPH (about 1700-1800 RPM) in 4th gear on a level road and maintaining a steady speed (very little gas pedal required), it's bucking. This is regardless of whether O/D is ON or OFF. Also, it bucks between 30-35 MPH (about 1500 RPM) under the same conditions. Typically, it doesn't shift into 5th gear until at least 50 MPH.
I'm sure there are several things that could be causing it to buck. What should I start with? Thanks.
