building my parts list. need some help | Ford Explorer Forums - Serious Explorations
Dan95-5.0
winnipeg, Manitoba
2004 Sport Trac
Im getting a list together for rockauto for all the stuff I need.
so far:
Transmission-Automatic : FilterRelated Parts
WIX Part # 58841 {#FT1087A} A
$13.65 $13.65 Remove Part
Emission : PCV ValveRelated Parts
MOTORCRAFT Part # EV268 {#2L5E6K773BA, 2L5Z6A666BA} B
$8.52 $8.52 Remove Part
Ignition : Spark PlugRelated Parts
MOTORCRAFT Part # SP500 {#AGSF22FMF6} Finewire Platinum B
$3.23 $19.38 Remove Part
Ignition : Spark Plug WireRelated Parts
NGK Part # 52015 {#FDZ080} NGK Wire Set A
$30.79 $30.79 Remove Part
MOOG Part # K80065 Caster Camber Cam Bolt Problem Solver
Front Upper; adjustment range from -1-5/8 to 1-5/8 deg. B
$18.01 $18.01 Remove Part
MOOG Part # K700542 {#52037712AB, 6L5Z5495AA} Problem Solver
Front; Incl. polyurethane bushings and solid metal sleeve for enhanced performance. Barrel nut allows for easier installation. B
$8.43
RAYBESTOS 5021021 - Front Left Upper Control Arm
RAYBESTOS 5021022 - Front right Upper Control Arm
I'm going to add a passenger side Timken wheel bearing hub. drivers side was replaced already.
now my question is I need to replace the pinion seal and cv to axle tube seal.
are these the correct ones?
pinion seal
http://www.rockauto.com/catalog/moreinfo.php?pk=1838836&cc=1427789
http://www.rockauto.com/catalog/moreinfo.php?pk=1117195&cc=1427789
cv seal
http://www.rockauto.com/catalog/moreinfo.php?pk=256970&cc=1427789
these the correct parts and seals?
Im getting amsoil fluids, installing the powertrax no-slip, bodylift, and shackles hoping in the spring.
thanks
Great parts list. TWO Moog K80065 camber kits, and TWO K700542 end links
are needed, one kit for each side. Sorry, can't help you regarding the seals.
Nothing wrong with WIX. Any reason you're not using the OEM Motorcraft FT134 tranny filter?
Yep 2 of each will be ordered. It didnt show when I copied and pasted it.
The only reason I went with the wix filter was because thats what amsoil sells with there products and I had the part number. I will look up the motorcraft
Thanks
