Bunch of Codes, Rough idle and poor mileage. | Ford Explorer Forums - Serious Explorations
Firemedic89
Explorer 2002
Hey all, New here. I have a 2002 Explorer with the 4.0 and 247,x... I've been having a poor idle issue and poor fuel mileage for some time now. The issue is worse some days then others.
Within the past few months I have changed plugs, wires, coil block (Motorcraft), Both front 02 sensors and side 1 bank 2 sensor.
I have AE and pulled the following codes off of it:
-P0171 System Too Lean (Bank 1)
-P0401 Exhaust Gas Recirculation Flow Insufficient Detected
-P0732 Gear 2 Incorrect Ratio
-P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit
-P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean
-P1132 Lack Of HO2S11 Switches - Sensor Indicates Rich
**Freeze Frame for DTC P0171**
Fuel System Status Bank One Closed Loop Fuel System Status Bank Two Not Reported
Calculated Load 71 % Coolant Temperature 190 F
Short Term Fuel Trim Bank One 3.90 %
Long Term Fuel Trim Bank One 24.18 %
Short Term Fuel Trim Bank Two 2.34 %
Long Term Fuel Trim Bank Two 0.00 %
Engine RPM 1653 r/min Vehicle Speed 50 MPH
Any help is greatly apprecieated.
A vacuum leak would explain the lean and high fuel trim codes. ..
check for vacuum leaks first, fixing that might remove some of those codes.
