BW-1354E to BW-1350M, Bolt in?
hvac man
Rifle, CO
93 Sport
I know, another silly question, but does a 88-89 Bronco II BW-1350M directly bolt in behind a 94 Explorer M5OD? (shift linkage aside)
I need a new t-case and found the 1350 here in town, and I would like to use it. I don't really care too much about the strength difference as this is a bone stock DD. I just need an answer before I buy the t-case :D
Thanks,
Clint
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 XL '16 XLT
yes should bolt right up, but I believe the out put is a different size or something for the front shaft, maybe different length . If you're not using the front axle then it should be a 30min swap to be up in running.
Just make sure the B2 wasn't 2wd. They came with a dummy case. LOL
hvac man
Rifle, CO
93 Sport
Cool, thanks for the reply. I called on it today and I'm just going to measure everything up on monday. If the front output splines are the same I wonder why a guy can't just swap out the yoke and call it a day?
HAHA, I would deffinately be the "dummy" in that CASE.
snoranger
Jackson, NJ
94 limited on 35's
The front is a slip joint on the 13-50, not a fixed yoke like the 13-54. The front driveshaft is a different length, by a few inches.
hvac man
Rifle, CO
93 Sport
1) Front driveshaft length- too short?
2) Slip yoke front output- fixed on 1354
Sounds like this is NOT the right option for me. Thanks for the help!
L BW 1354e Shift repair Transmissions & Transfer Cases 1
mr cribb 4x4 dash light fix after 1354E to 1354M swap Transmissions & Transfer Cases 8
B 1354e front flange Transmissions & Transfer Cases 2
C 1354e into 2wd ex question Transmissions & Transfer Cases 1
I 1354e to 1354m swap wiring Transmissions & Transfer Cases 8
K 4405 to 1354e help and info Transmissions & Transfer Cases 0
0 BW 1354E to a 2000 5R55E Transmissions & Transfer Cases 1
S 1350m shift linkage work on 1354m? Transmissions & Transfer Cases 15
RangerX M5OD frozen fill bolt Transmissions & Transfer Cases 3
C broke 2 bolt heads 5R55E Transmissions & Transfer Cases 3
P Servo Covers + Leaking Band Bolt Transmissions & Transfer Cases 1
L will a 91 ex tcase bolt to a 97 Transmissions & Transfer Cases 6
S 5R55E valve body bolt thread pitch Transmissions & Transfer Cases 3
S 96 5.0 AWD transfer case do I have a 6 or 4 bolt? Transmissions & Transfer Cases 0
B Transmission Bolt in. Transmissions & Transfer Cases 0
1 Broken valve body bolt Transmissions & Transfer Cases 3
G Solved Heat shield bolt specifications for the 5R55E. Transmissions & Transfer Cases 1
C Which transfer cases will "bolt-in" to 97 Explorer Control Trac Transmissions & Transfer Cases 5
A A4LD Bellhousing Bolt Reinstall Issue Transmissions & Transfer Cases 3
G Diff pin bolt extraction Transmissions & Transfer Cases 7
J 4R70W mount to transmission bolt size? Transmissions & Transfer Cases 0
HiImBrian Broken Band Adjustment Bolt Transmissions & Transfer Cases 20
T Sonnax 4R44E-5R55E Solenoid, Valve-body bolt length/location and spring info Transmissions & Transfer Cases 2
B 89 m5r2 5 speed trans Bolt to a 4.0 ohv ? Transmissions & Transfer Cases 2
M Which engine does this bolt to? Transmissions & Transfer Cases 1
K Missing Bell Housing Bolt Transmissions & Transfer Cases 2
C A4LD band adjustment bolt size? Transmissions & Transfer Cases 1
K 5r55e bolt question Transmissions & Transfer Cases 5
E HELP!! Stuck Shackle bolt! Transmissions & Transfer Cases 23
L what transmissions bolt to 4.0 sohc Transmissions & Transfer Cases 0
T 5R55E band adjustment bolt issue Transmissions & Transfer Cases 5
M Transmission dipstick tube fell out, lost the bolt Transmissions & Transfer Cases 0
O 6 bolt, fron- DS help, HELP!!!! Transmissions & Transfer Cases 7
M Pan Bolt Size 5R55E PLS! Transmissions & Transfer Cases 3
E Taking off Transfer case, top-passenger side bolt to tranny question.. Transmissions & Transfer Cases 4
U Auto gearbox pan bolt torques Transmissions & Transfer Cases 1
F A4LD valve body bolt configuration. Transmissions & Transfer Cases 2
P change transfercase flange to 4 bolt? Transmissions & Transfer Cases 45
M 97 AWD to 4WD bolt in swap? Transmissions & Transfer Cases 8
S 4405 Transfer case torx bolt size? Transmissions & Transfer Cases 1
L Front Stabilizer Bar link and bolt. Transmissions & Transfer Cases 2
9 1991 3.0 Manual ranger bolt up to 94 4.0 ex? Transmissions & Transfer Cases 2
S Stupid Bolt size question...Please Help! Transmissions & Transfer Cases 2
8 Front axle bolt size Transmissions & Transfer Cases 3
G Pinion Shaft Lock Bolt Is Rounded Off Transmissions & Transfer Cases 1
T Trick for getting at top bolt on 4405??? Transmissions & Transfer Cases 2
X A4LD bolt on swap???? Transmissions & Transfer Cases 3
WickedWindsor Front Diff Bolt Location Transmissions & Transfer Cases 1
B VB bolt torque specs Transmissions & Transfer Cases 6
D Drive shaft bolt question Transmissions & Transfer Cases 9
Similar threads
