xdviper
- February 15, 2007
- 1997 XLT
I've installed a new head-unit on my 97, without the JBL audio system but with the AUTO button on the factory unit. This meant I have to bypass the amp that is the rear of the vechicle. I connected the new JVC headunit via the harness that connects to the factory amp and distrubutes sound that way.
Now the problem is, just a few days ago, the left side has been going in and out. When I turn up the volume, the left will start working again, let it go down, it'll be mute. I've taken off the door panels and checked the wires and everything is firm. I'm also using 4 aftermarket speakers that worked before and after I installed the new headunit.
I've troubleshooted my way down to the amp being the culprit. I have the amp bypass harness (a bunch of long wires) and haven't installed it yet since it was working fine. But want to get a few ideas or tricks before I go ahead with the bypass.
Would the amp be responsible for the left side going in and out?
And how would one bypass the amp? Where do I run the wires from? And how? Under the carpet? Can this be tackled by someone who has no experience taking apart a whole car?
I know I can run the wires from behind the head unit to the glove compartment and then what? Thanks!
