celly
disturber of the peace
- July 28, 2004
- calgary
- 99 eb 5.0 awd
I just scored a '99 Eddie Bauer with the 302 in it. I traded in my Sport with 4.0 SOHC in it, so obviously a lot of parts won't swap over to the new engine. I was wondering if anyone who know if I could use for C&L MAF that I used on the 4.0 on the 5.0. Keep in mind that the C&L isn't a MAF itself, but just a larger body. It doesn't have it's own electronics, and uses the stock guts (you unscrew it from your OEM MAS and insert it into the C&L).
I asked Doug Studdard of Bamachips what to do. He told me he's never tested this particular part on the 5.0 so he couldn't say with certainty if it would work or not (I appreciate his conservative approach). In fact, he got a bit more technical:
"I wouldn't swap it onto it unless you had some sort of wideband 02 sensor setup you could keep track of the a/f with. You could be running too lean with it."
I'm a mental midget when it comes to technical issues involving the engine, so I'm not really sure what that means.
Has anyone actually done something similar with their 302 and got it to work safely? The C&L MAF body is larger than stock, but not by a huge amount. I had the C&L on their briefly last night and it ran fine and smooth as silk. I don't want to cause any longer term issues so I promptly took it off this morning. I'd appreciate other people's input who may have some a similar swap or have ideas on how to make it work. Otherwise, the C&L is up for sale soon. I'd rather not part with it. The addition of this MAF to my SOHC made a subtle difference and I wouldn't mind something similar on the V8.
TIA
TIA
