C6 help | Ford Explorer Forums - Serious Explorations
C6 help
Bootless
1994 ford explorer 4x4
So I'm converting a 2wd c6 to a 4x4 and I don't like how it just has a vent cover is there any way to run a hose instead?
Sure, work the metal cover off and attach a hose to the vent or remove the whole thing and either tap the case for a fitting or find a metal tube that fits tight and epoxy it in.
Use a screwdriver to work the cap off, but you find the vent end is kind of large to get a hose over it so you might want to drive the whole vent out and grind down the end to get a hose over it. Its not the best fit but it will be ok for a vent.
Or tap the hole and insert a brass fitting, this seems to work out the best.
