cabin air filter | Ford Explorer - Ford Ranger Forums - Serious Explorations
cabin air filter
idrojdpj
Wichita, Kansas
1997 XLT 4 door 4x4
I want to find out if there is a cabin air filter on my '97 X. I've done a search but did not get what I was looking for. My problem is a very bad moldy smell when I turn on my a/c after my truck has been sitting for a few hours. I have used the cleaner kit to clean my a/c coils but that gets exspensive at $25 per can. What do ya'll suggest for cleaning and is there a cabin filter?
Thanks
DJ
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
how long does the smell last for? If it's under 30 seconds or so that's normal.
SWLathrop
Yorkshire,NY
01 & 02 Stang, 94 Sable
The is no CABIN AIR FILTER on the X's. Also, even if there was, the filter only filters out dirt. It doesn't stop the growth of mildew on your A/C evaperator. As far as the cleaner goes, just use LYSOL. It's cheaper and actually works better than the FORD cleaner or Frigi-Fresh.
idrojdpj
Wichita, Kansas
1997 XLT 4 door 4x4
Thanks guys. I have used the DWD2 cleaning system can I use the lysol the same way I would use the DWD2 method?
GR899V8
Oregon City, Oregon
'99 Limited V8 4WD
I was told I have a cabin filter, but have never been able to find it. They said under the cowling cover, but I've removed it and can't see one.
Jon_Herr
2011 Ford F150 FX4
No filter
There is no filter - but Ford is aware of the problem.
If you can find it there's a TSB related to a timer circuit that runs the blower motor for a couple of minutes after the truck is turned off.
This is supposed to dry out the A/C so mildew cannot grow.
Jon
frj00
Allentown PA
99 Sport 4wd 4.0 SOHC
I have the same problem on my 99 sport, no filter but where can I get the spray stuff
Robb
BG makes an A/C system cleaner. It is about $20 a can tho. I have only seen it at garages also. I am sure you can get it online somewhere.
Robb
