    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
Cabin fuse box location / access
jsgoofn
Beautiful Colorado
2015 Ex Sport
Hello, all,
Has anyone had the distinct pleasure of trying to replace any fuses in the fuse block located on the driver side of a 5th Gen EX? Not the convenient one in the engine compartment. It is located in the most inaccessible location that the Ford engineers could have come up with. You have to literally lay down on your back on the floorboard fitting yourself underneath the brake pedal while leaving your arms and hands free to hold a flashlight to see the fuses. Then you have to find the fuse you want to replace (after memorizing the locations), pull it out with the handy fuse puller which is also located in this lovely area and then hopefully get the new one in the right direction to put it in. If you have been successful, can you share your experience and if you found a way to do with this without turning yourself into a pretzel? I am probably going to hire a circus performer contortionist to do this...:banghead: Thanks!
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
^^ Your thread was merged with this one. As you can see, you are not alone.
