Cabin Fuse Box Location (PIU 2013)
lovemyfordpiu
2013 PIU
I can't seem to find this sucker for the life of me. Everything I've seen says it should be down and left of the steering wheel. I have all the panels off underneath there and while I see a bunch a bunch of wires (to include a remote start box I didn't know it had) there is not fuse box. I dug through the wires with a flashlight even to ensure I'm not missing it. Can someone shed some light on this? Am I looking in the wrong place?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
If it is in the same location as the retail unit, then you seem to be in the right place. It is to the left of the steering column attached to the left side of the body. Should be somewhere above the parking brake. Here is a picture I took of my previous 2011 Limited; Cabin fuse box location
lovemyfordpiu
2013 PIU
Thanks Peter. I must be a bit dense but I’m not seeing the fuses in the image.
peterk9
Staff member
Moderator
Callsign
VE3
You won't see the fuses. Apparently, from what I've read, there is a cover on the fuse box itself.
Only1Badboy
St. Paul Minnesota
2014 Explorer Police Util
I had to do this yesterday. Ill pop it out and show you one second, ill grab a photo. IT is kinda high up ...
