Lavelle Barker
- May 24, 2017
- Wellington, FL
- 2006, Mountaineer Luxury
Hey guys. I've got a 2006 Mercury Mountaineer that we keep having water leak problems out of. We've recently moved to South Florida so we get a ton of rain and I need to figure this out, quick. The first problem was there was water coming down the middle row seatbelts. A lot of water. Soaking the headliner and leaving water stains. The seatbelts line up perfectly with the roof rack so I figured they were they culprit and with some research it seems this is a common problem. We removed the roof racks and resealed all the bolt holes and reattached the rack. Now there's the problem of water coming in the map lights/front top console area where the rear air controls are. It doesn't look like the sunroof is leaking and the headliner isn't wet around the sunroof, but it is wet around the plastic on the top console. Has anyone had this problem and how did you fix it?
Thanks!
Thanks!
