The interior in a rugged condition and needs cleaning. Don't be afraid of my email I am a peaceful man. I would eventually replace the Drivers door. Like I said it needs the wheel bearings gone threw.asoundalso the gas gauge doesn't work which is common. It's got nice looking tires and rims and a nice push bumper.
There's no check engine light and I would be willing to smog the Explorer. I have cruised it at 65 but I think the bearings made it feel a little whacky so I cruised at 55. I have not drove very far in it. I have probably put 100 miles on it. Yesterday was the first time that I have been under it since I got the vehicle. It showed signs of leaking. I believe it's engine oil from the pressure sender. I tried to tighten it but I think the sensor might need replaced. I will be keeping an eye on it but expect that where the oil has been coming from. I cleaned up some of the grease and went and changed , tranmission fluid which was almost up to level but dirty/ little metal in the bottom. I changed the fluid in the transfer case and toped off the front diff. I also changed the oil and filter. I won't take a thousand for it at this time. If you know how to do work on vehicles than you could probably go threw it and get it driving good. I was told it was on non op but I haven't went to the DMV. The tag on the plate is 2017 and I have the title signed by the owner but not filled out by me. Also there is quite a bit of service records on it.
