Hawkeye999
- June 17, 2004
- Huntsville,AL
- 92 XLT
I have a 92 2WD that needs alignment. The shop showed me a stock camber bushing that had a tab on it that did not allow adjustment, it was set at the factory. They said that they needed to be replaced for alignment to be done. They quoted me $80 for the job and then the charge for alignment. Is this a job that has to be done by the alignment shop or can I replace the bushings and then have it aligned? While researching this I have noticed that there are several different bushing sets that show an adjustment range that varies from 0 degrees on one set to -3 1/2 to +3 1/2 degrees on another. Would it be wise to get the ones with the most adjustment or is this also something that needs to be determined by a specialists? Thanks
