Yes they are "normal" pistons, and the GT40 style head needs those. There are really only two piston types to look at, the normal valve reliefs, or the TFS Twisted Wedge type. So you need typical 302 pistons. I've slowly watched and searched for feasible pistons for a couple of years. I thought until recently that a cast or hypereutectic pistons was going to be the best choice. But if you look for a while, you'll see two cheap level choices. The garbage stock replacement stuff can be as little as $125 or so for a set(no rings), and the upper level of cheap will run $300 or more, and have no rings. So assuming you don't want to risk the cheap cheap pistons, you're looking at $350 or more after buying rings also, maybe $400 with high level rings.
That is a lot, I know. I built my first Cleveland in 1980, and forged TRW pistons then were about $25 each. They still make those pistons, but they are near double I think, last I looked.
Getting the compression you want is a tough part. It's hard to gain compression with a 302 in rebuilding, unless you buy very small chamber heads, or choose near flat pistons, and zero deck. I have 58cc heads for my project, which is kind of a standard size for 302 heads. To get upper 9:1 it leaves few pistons choices in that $300+ range. So in a recent Corral thread, a few links were posted for nice forged pistons. The one I liked the best was a Wiseco piston, $500ish including nice rings, and they weigh less than the KB $300 pistons. The cast pistons are in the mid 500gram weight, while the Wiseco was 465grams each. Figuring the $100 difference in price, I'd prefer the lighter forged piston, which is a very high quality part.
I think this might be the Wiseco piston, but it's from an old search I had in an open tab. If not it's close, and this one is $395 with the rings, unknown seller;
PTS500A3 - 4.030 bore
AD Performance 302 Flat Top 3.00 Forged ProTru Pistons w/ rings [PTS500A3] - Wiseco ProTru Forged 302 or 393 Stroker Flat Top Pistons, Forged 4032, Coated with JE Rings Probe PN: PTS500A3 - 4.030 bore Flat Top 5cc Valve relief, Inline Relief 1.600 Compression Height for stock 302 rebuild or...
www.adperformance.com
