Centaurious
- April 28, 2015
- Pensacola FL
- 1994 Explorer Sport
I have a 1994 Explorer with the windowed Syncro unit. I wondered if the later model with the straight connector had the same spec Hall Effect unit inside and if the interrupter on the end of the shaft was the same shape.
I know some of the interrupters are a semi-circle and some are a small tab. This would greatly affect what signal the sensor sent to the ECM. Both units are a 3 wire sensor.
The reason I ask this is I'm getting a 214 CM code and I noticed that the sensor was loose in the housing and would turn left and right a small amount. Pricing the units the 1994 unit is much more expensive than the 1996 unit. and would save a lot even with a replacement connector.
Thanks for your help.
