Can a Brake booster leaking vacuum...
ranger7ltr
Great State of Texas
1999 Sport
Can a leaking brake booster cause a lean code? My truck started throwing P0171 and P0174 codes at me recently and I know the booster leaks as I have no brake pressure 10 secs after I kill the engine...My vacuum gauge though shows a good solid 20-22 in./hg. vacuum so it can't be a big leak...I guess...
The intake gaskets should not be leaking as they were installed about a year ago and the bolts are tight...
I have been tracking down vacuum leaks and it would seem that the more leaks I fix the more the lean codes show up...I replaced vacuum lines to the purge valve, the pcv valve, and i am checking the rear canister lines this weekend...
And the truck runs fine so if it is a vacuum leak it is not affecting driveability...
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Definitely can and usually does.
jremington59
Watertown, NY
1997, 99 and 2000 5.0's
It could be a dirty MAF sensor but if you know you have a vac leak it very well may be that.
budwich
Ottawa, Ont
96 XL
there are ways to test your booster based on response of the pedal to force at idle and revved... search should help. I would agree with previous post that you might be "barking up the wrong tree".
Radiojunkie
Mesa AZ
91 XLT
My brake booster also leaks and I now use it in "manual mode". Yes, it will be a big vacuum leak to your engine. I plugged off the intake side for now until I can get a new booster. About 60 bucks at autozone.
