ocmnelson
- January 3, 2012
- Orange County, CA
- 2006 Explorer AT w/RSC
I have a 2006 Explorer V6.
Ran perfect. On the way home Got a CEL P0442 code
P0442 - EVAP Control System Leak Detected (Small Leak)
Now the twist, I'm hoping this narrows down the problem. It started happening a day or two after the CEL light when on. Normally when I am coming to a stop and my truck downshifts into first gear from second it has its normal rev from downshifting. It now revs down but loses the back pressure somewhere. At the same instance my truck downshifts and revs my brakes loose pressure for a half second and then back to normal. ?????
So there is an Evap leak that is effecting my braking power or pressure.
By the way it is not my gas cap I had this issue earlier this year and bought a cap from the dealer and never had the problem again. I also had a new cat put in (if that helps) around the same time the gas cap was bought.
Please help.
Please help.
