84FLH
- February 14, 2016
- 2000 Mercury Mountaineer
Ongoing research....
2000 Mountie. 4.0 SOHC. 320,000. Runs good for it's mileage.
With hands at 12 and 6 o'clock on driver's front tire, wheel bearing has 1/8"-1/4" movement. But I've no howl, whine, grinding or other noise typical for bad wheel bearing.
3 days ago I heard two extremely loud metal on metal bangs, about 1 second apart, from front end while driving 5-10 MPH in straight line.
I stopped and looked under vehicle. Found nothing obviously wrong.
Continued driving slowly, straight. Got the 'double tap' bang once more. Another under vehicle inspection found nothing out of order.
Drove 15 miles home 50 MPH without further banging.
Enroute to work next day, the 'double tap' banging returned. About 4 times w/in 100 yard stretch.
Could the bad wheel bearing be causing the CV joint to make this noise?
It's *very* loud. Like someone hitting frame with 2lb sledge.
My impression was of a spinning metal part hitting another. Or a heavy metal part under tension being let loose and hitting a solid metal part.
Thanks everyone for your answers.
