I was looking at other peoples measurements for hours and they're all different, turbo, AWD, FWD, towing package, 4 cyl etc etc. I wouldn't mind if I had bought the H&R springs and it sat at the same measurements as yours, except I'd rather have 1/2" of rake instead of 1" (the lower the vehicle the more obvious the front to back height difference). This way I didn't feel silly buying springs then adjusting them to fit what I was looking for, I know for Mustangs and other popular cars they had different springs for different engines, different options/weights etc.
For the rear I would rather cut off a section of the rear spring than buy the entire set to use only half the kit, yes I did call H&R to confirm. The other issue I was worried about if the spring rates would give a strange feeling only using half the kit. When I tested mine after lowering it feels perfect, guessing maybe 15-20% stiffer over stock but not at all harsh or even close, it does have that stiffer performance feeling over bumps similar to a sports car.
A lot of the Explorer Sport/Interceptor Utility people are shocked that the drop the H&Rs give isn't as much as the non sports since they already come "lowered".
