mrklai
- March 7, 2011
- 01 ST|04 EX XLT
Long story short, got the vehicle about 2 months ago, after about $500 worth of diagnostics, finally got a wiring diag done and was told I need a new abs module. 3000 miles and 25 salvage yards later, I found one in NJ and purchased it. Had it installed and took it to get calibrated/programmed at the stealer this morning and was told the codes would not clear, but he was able to program the VIN. He recommended I buy a new abs pcu for $800. I received the following codes after install (I figured why not?)
1. U1900 - CAN Communications BUS Fault
2. C1998 - Pressure Controller Plausibility Fault
3. C1165 - Right Rear Speed Sensor Input Circuit Failure
4. B2477 - Module Configuration Failure
5. C1281 - Lateral Accelerometer Circuit Failure
I am thinking electrical, main ecu, but don't know enough to really make that assumption. I had the right rear speed senor replaced a few weeks back and it is still on the vehicle (just climbed under to see it). So I guess I'm wandering if anyone can shed some light on the other 3 codes (1, 2, and 5) to help me out because I'm getting short on patience and money. Any help is greatly appreciated.
