Tekime
- October 10, 2008
- 2000 Eddie Bauer
Hi all, I could really use a bit of help.
My 2000 Explorer V8 Eddie Bauer just started making a horrible rattling noise from the front left area of the engine. I searched around and fear this might be the transfer case, and I could use any advice at this point.
I bought this truck ~6 months ago from a local dealer and it has been great so far - strong through all gears and I put about 12k on it so far (about 125k on the engine now). Last month I damaged the left front tire and went to have it replaced (after driving on it for a few weeks with an unnoticed ribbon worn off the inside edge). I was told that running the wrong size tires can cause wear that may damage the transfer case. They also discovered that the front left tire was the only *correct* size for the truck - the rest were just one size larger. So I put four new tires on it of the correct size a few weeks ago and put ~500 miles on it since.
The noise just started - I thought I heard something a few days ago but only briefly. On my way home it started in very badly and did not stop. It's a very loud metal clanking/rattling noise. The noise seems to follow RPM not wheel rotation. When revving it starts clanking/rattling louder. When I speed up a bit and then let off the gas it clanks even more loudly and the frequency slows down. I can almost get it to stop by revving the engine just slightly while rolling. It's quiet while idling at a stop.
I don't know a heck of a lot about this vehicle, or AWD in general, but it almost seems like there is still power from the other 3 wheels, but whatever is supposed to be driving the front left isn't syncing up or is slipping.
Very appreciative of any advice you folks might have!
Thanks,
Gabe
Thanks,
Gabe
