Can't get camber in Check with Lift. | Ford Explorer Forums - Serious Explorations
mutti_wilson
Battle Ground, WA
94' 4dr XLT
Maxed out on my camber adjustment my tires look like this \--/ about an inch of overhang. I put 2 inch coil spacers in. I have 4 inch drop brackets already and 6 inch ones would be nice, but can yo buy them separate? I was thinking about milling the adjustment slot longer and welding on new guides. Is this insane or a good idea? Does toe in cause problem with camber? And will i need to drop my radius arms or are they fine?
did you already have a lift installed before you put the coil spacers in?
