Can't See Turn Signal Indicators
Ironworker40
new jersey
2015 Explorer XLT
As thee title states, with the steering wheel in the position I like it in I can't see the indicators. Anyone else have this problem? Has anyone come up with a solution other than tilt the wheel up. A couple of small light mounted ontop the top of the the dash would be nice. Like little 1/8'' diameter that you see for alarms.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
The only adjustments to remedy that is to change the steering wheel or seat position. I guess in many vehicles you could run into the same problem. Since this is the first time it has been brought up in 7 years that I can recall, I don't see any way around it except for what was mentioned. Good luck.
Ironworker40
new jersey
2015 Explorer XLT
I ordered a couple of 1/4'' diameter light I'm going to mount somewhere I can see them. Does anyone have a wiring diagram for a 2015 to locate were I can tie them in without going thru the firewall
peterk9
Staff member
Moderator
Callsign
VE3
T Changing Turn Signal Lever? Stock 2011 - 2019 Ford Explorer Discussion 18
Bobs2018Explorer Upgrading basic outside mirrors to turn-signal mirrors Stock 2011 - 2019 Ford Explorer Discussion 25
T Whelen turn signal bulbs changed Stock 2011 - 2019 Ford Explorer Discussion 0
A Turn signal Stock 2011 - 2019 Ford Explorer Discussion 1
M 2015 Explorer Sport Side Mirror Turn Signal Stock 2011 - 2019 Ford Explorer Discussion 2
Q Right Turn Signal not working Stock 2011 - 2019 Ford Explorer Discussion 27
J Turn Signal Will not Stay on Right Turn Only Stock 2011 - 2019 Ford Explorer Discussion 5
B Turn Signal reset Stock 2011 - 2019 Ford Explorer Discussion 2
T Turn Signal 4 blink problem Stock 2011 - 2019 Ford Explorer Discussion 4
M Changing Turn Signal Lens 2014 explorer Stock 2011 - 2019 Ford Explorer Discussion 0
M Mirror Turn Signal Wiring Stock 2011 - 2019 Ford Explorer Discussion 0
W broken turn signal lens on exterior mirror 2011 explorer Stock 2011 - 2019 Ford Explorer Discussion 0
T Frustration with turn signal lever Stock 2011 - 2019 Ford Explorer Discussion 28
3 turn signal Stock 2011 - 2019 Ford Explorer Discussion 6
P Replace the mirror turn signal light strip Stock 2011 - 2019 Ford Explorer Discussion 19
3 Left turn signal not working..only flashes 3 times Stock 2011 - 2019 Ford Explorer Discussion 13
D A ? for those that have had their turn signal lever replaced..... Stock 2011 - 2019 Ford Explorer Discussion 0
Pete165 Notchy Turn Signal Lever FIX Stock 2011 - 2019 Ford Explorer Discussion 65
G Turn signal flasher relay Stock 2011 - 2019 Ford Explorer Discussion 34
S Turn signal oddity Stock 2011 - 2019 Ford Explorer Discussion 6
S Emergency: 2011 Ford Explorer XLT right turn signal stuck, won't cancel!! Stock 2011 - 2019 Ford Explorer Discussion 28
T Has anyone modified their 2016+ so they can turn off their headlights? Stock 2011 - 2019 Ford Explorer Discussion 9
A Hazard lights turn on by themselves Stock 2011 - 2019 Ford Explorer Discussion 1
J 2013 ford explorers defroster will not turn off Stock 2011 - 2019 Ford Explorer Discussion 5
E Intermittent Noise When Making A Left Turn Stock 2011 - 2019 Ford Explorer Discussion 2
P Heater won’t turn off Stock 2011 - 2019 Ford Explorer Discussion 1
MrWickd Interior lights/puddle lights won't turn on Stock 2011 - 2019 Ford Explorer Discussion 2
R 2013 to 2019 Upper Strut Mount - Does not turn freely, normal? Stock 2011 - 2019 Ford Explorer Discussion 6
D 2016 Driver side heated seats wont turn off Stock 2011 - 2019 Ford Explorer Discussion 5
R How can I prevent cabin lights from turning on every time I turn off engine? Stock 2011 - 2019 Ford Explorer Discussion 2
D Turn Key, wont crank for a few seconds Stock 2011 - 2019 Ford Explorer Discussion 10
Partsman109 2011-2015 Explorer front turn/parking lamp...is there a cool way to minimize the amber? Stock 2011 - 2019 Ford Explorer Discussion 6
M 2012 ford Explorer popping when i turn Stock 2011 - 2019 Ford Explorer Discussion 0
N Question on Front Running lights and turn signals Stock 2011 - 2019 Ford Explorer Discussion 9
J Emergency lights automatically turn on during emergency braking Stock 2011 - 2019 Ford Explorer Discussion 21
D Cruise control inconsistently works - wont turn on. Stock 2011 - 2019 Ford Explorer Discussion 2
E Can't turn the AC off Stock 2011 - 2019 Ford Explorer Discussion 8
D How to turn lights off when idling Stock 2011 - 2019 Ford Explorer Discussion 39
I Heat won't turn off Stock 2011 - 2019 Ford Explorer Discussion 11
B Wiper doesnt turn off Stock 2011 - 2019 Ford Explorer Discussion 10
M Explorer didn't turn off after walking away with key fob Stock 2011 - 2019 Ford Explorer Discussion 8
D Is there a way to turn down the volume for the navigation prompts? Stock 2011 - 2019 Ford Explorer Discussion 10
M Interior Lights/Puddle Lights Won't Turn Off Stock 2011 - 2019 Ford Explorer Discussion 8
C Not Ready For Inspection : Sensors resetting during ignition turn off Stock 2011 - 2019 Ford Explorer Discussion 7
P 2013 Explorer: Ticking Sound and RPM issue when A/C is turn on Stock 2011 - 2019 Ford Explorer Discussion 5
P Opinions/Experiences wanted: Engine won't turn off Stock 2011 - 2019 Ford Explorer Discussion 5
A 4.2" screens in gouge cluster spontaneously and repeatedly turn off and on Stock 2011 - 2019 Ford Explorer Discussion 3
S Radio won't turn on Stock 2011 - 2019 Ford Explorer Discussion 57
D I swear I hear a fan noise when I turn on my Heated Seats. Stock 2011 - 2019 Ford Explorer Discussion 9
N You can remove your seat belt while driving and no "belt minder" will turn on Stock 2011 - 2019 Ford Explorer Discussion 12
Similar threads
