Chew_12
Working
- December 2, 2002
- Chandler, AZ
- '93 XLT
First of all when I put it in gear and step on the gas the rpms go up and go down and then up, ill put on the brake and it will still do this. When I stop it sometimes stalls. I noticed that if I floor the pedal the rpms only go to 2000 but when it is idle i can floor it and it will go as high as it normally does. When it is idle it will be fine for a couple of minutes then the idle will flucuate and then stall. The car doesnt seem it will go over 20. I dont think it is the transmission because there arent high rpms, but I dont know. My transmission fluid is low, would that cause this? Right now I cannot go anywhere because I do not have a car, and very little of my friends do. There is a CEL with the car starts to act funny but AutoZone is far away and I cant get there in this condition.
I was having a previous CEL of 341 which is the octane adjust service pin. That CEL would only come on rarely and its been like that for a month. Would this cause this problem? I also get very bad milage. I checked hoses for leaks but I do not hear any, though still possible. What do you guys think it is?
Please Help with CODES 511,341,10,111.
Another Note when I turn the key the fuel pump does not turn off.
