Carb+5.0+PATS=?
Truckinmario
Vienna WV
99 Explorer
i have in my garage a rebuilt 5.0, brand new internals that's carb'd. I'm planning to put this in my 99 explorer. Given the pats system will largely remain untouched, everything should work since the engine will (obviously) not have an ecm.
Is this correct, or am I way off base and need to reconsider and a find a solution?
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
are you using the efi from the truck, or have you converted the truck to carb?
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Convert the truck to carb and you won't have any issues with pats after you run your 1 starter signal wire. Or you take all the carb junk off and replace it with the explorer intake and sensors then the computer can stay untouched.
Truckinmario
Vienna WV
99 Explorer
Thanks! That's what I was curious about!
VR4
vancouver, wa
01 explorer
Best option. Put the carb junk on Craigslist.
96ex5.0
canyon tx
96 explorer 5.0 4x4 5spd
I love my carb swap, are you using the stock trans? If do you have to keep the computer it tells it when to shift.
Truckinmario
Vienna WV
99 Explorer
If I use this motor in going to use a t-5 instead of the auto.
