Cargo area LED bulb on '14 Sport | Ford Explorer - Ford Ranger Forums - Serious Explorations
Bigb348
Brooklyn, NY
2014 Ford Explorer Sport
Hi
I am trying to find out the correct bulb to order to swap out the cargo area light(not 3rd row light)
Thanks
dcpatters
2014 Explorer Sport
If I recall, the bulb is longer than 31mm. I had adjustable ones, 31-36mm LED festoon and they were not correct. It's easy to pull the cover off and look for a measurement. Should have followed my own advice though.
I ordered the puddle lights, which fit, but the same size for the cargo area did not.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
285ferrari
Maryland
2014 Sport - Darth Vader
peterk9
Staff member
Moderator
Callsign
VE3
Maybe I missed it, I didn't see anywhere in post 155 or that thread that specifies which bulb to use in the cargo area.
That post just showed the DIY step. I didn't check back through the entire thread for the actual bulb but assumed someone may have mentioned it. Look at #114 . Perhaps you can send a private message to the poster and ask what kind of bulb he used.
christglenn
petersburg,michigan
2014 ford explorer sport
cargo area led replacement bulb
the bulb that you need is #de3912 6 bulb led the body is 39mm long and its 8mm body it is a 3 watt festoon bulb. hope this helps everybody out
