IgotTwo
- January 7, 2001
- Branchburg, N.J.
- 94 XLT - 97 XLT SOHC
Any help on this one would be greatly appreciated.
-My AC crapped out a few days ago.
-Not cold air, all blowers are working
-Compressor clutch is not engaging.
-A\C recycling switch was jumped, hoping to find some life at the compressor and it did engage.
-Pressure gauges initially showed very low readings on both high and low sides. Low freon seemed very likely.
My first thought was to be merciful on the system and get SOME freon in then go for the leak detector.
The charge took very little of a 16oz can when the compressor clutch started cycling at regular 5 second intervals. From that point on, it seemed it didn’t want to take any more freon.
I put the gauge back on the high and then the low side and both pulsed in synch with the engaging compressor clutch, same 5 second intervals.
Low side 20–40 High side 50-90.
Over night, the freon level must drop and when I start it up there is no clutch cycling and the pressure readings have dropped ……….until I repeated the charging process.
I can’t determine if the high and low pressure line pulse with the clutch engaged because it doesn’t stay engaged…… something about the compressor reeds? (so I’ve read)
I went thought a series of voltage\resistance test from Helm’s and could only come up with “no 6volts TO” the A\C high pressure switch (that I’m going to recheck) that leads to check Circuit 441? right! that’s after 440 and before 442! which is another treasure hunt.
Bottom line:
A major leak seems a given.
The system takes very little freon to get the clutch cycling and I can’t seem to get past that point.
Can anyone help the unenlightened whose going up the learning curve?.. Point me in a direction? …or tell me where I’m spinning my wheels?
No gas and Zippo lighter jokes PLS (just kidding)
Bottom line:
