Cat Back Exhaust - Stock or Custom?
Mike_J
Location
Somewhere in the desert....
1993 Explorer Sport 5spd
93 Explorer Sport, 5-Speed, 2wd, 303k mi
It's coming time for smog check and my tailpipe rusted off the original muffler again. So now I'm looking into replacing everything from the cats on back. Definatley time, the heat sheild on top of the muffler came loose and rattles.
Currently I've been looking into replacing the intermediate pipe, muffler, and tailpipe. The big question for me though is go with an OEM style stock replacement, or go with a high flow unit like some of the Walker FX units. I know custom can lower backpressure and might give some performance and gas mileage gains, but then I'm still getting 20mpg on the avg so how much would it really improve.
Also trying to decide on whether I want to give the truck more growl or go back to the stealth quiet sound it has with the tailpipe and stock muffler as I like both.
Any real gains or plusses to either. I read somewhere on the forum that lower back pressure means more high RPM power, but I tend to sip gas at higher gears and lower RPM and quite like how she handles currently, don't want to trade one for the other.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
I had a bigger seat of the pants improvement going to a high flow cat than I did adding a cat back system. I did the cat back first and didn't notice much if anything.
However if I added a high flow cat first, and had left the stock after cat exhaust, it may not have produced the results that it did.
D muffler or Cat back exhaust kit Stock 1991 - 1994 Explorers 5
P $60 cat back exhaust Stock 1991 - 1994 Explorers 10
C Exhaust Question: Y-pipe to CAT connection? Stock 1991 - 1994 Explorers 1
W Exhaust Leak 2nd Cat / Muffler Pipe Stock 1991 - 1994 Explorers 7
T Exhaust Hardware size for 'Y' pipe to Cat Stock 1991 - 1994 Explorers 0
U Exhaust leak between muffler and cat. Stock 1991 - 1994 Explorers 8
C cost of cat back exhaust Stock 1991 - 1994 Explorers 2
W 94 explorer bad cat con symtoms Stock 1991 - 1994 Explorers 1
M cat question Stock 1991 - 1994 Explorers 7
M Gibson 19677 Cat-Back Stock 1991 - 1994 Explorers 4
N Cat converter question Stock 1991 - 1994 Explorers 12
SwaintaN which way does the cat pipe go? Stock 1991 - 1994 Explorers 5
M Y pipe to cat bolts Stock 1991 - 1994 Explorers 15
E cat and o2 sensor Stock 1991 - 1994 Explorers 4
T Where at @ LMC cat? Stock 1991 - 1994 Explorers 7
P cat convertor clogged? 92 explorer 4x4 Stock 1991 - 1994 Explorers 18
B Plugged cat? Stock 1991 - 1994 Explorers 1
T y pipe cat question Stock 1991 - 1994 Explorers 4
A Cat. Converter question Stock 1991 - 1994 Explorers 5
9 new development, cat. converter out. Stock 1991 - 1994 Explorers 6
James909 Importance of cat heat shields Stock 1991 - 1994 Explorers 6
D Cat Converters Stock 1991 - 1994 Explorers 16
jrgaylor Plugged cat? Stock 1991 - 1994 Explorers 5
T cat converter problem? Stock 1991 - 1994 Explorers 5
T cat converter Stock 1991 - 1994 Explorers 13
G Ca. smog fail, new cat Stock 1991 - 1994 Explorers 6
B Could the cat be gone? Stock 1991 - 1994 Explorers 0
1 Is it wrong to install heads with exhaust manifold atached Stock 1991 - 1994 Explorers 5
massacre Exhaust Manifolds? Stock 1991 - 1994 Explorers 3
C 94 Explorer stock exhaust pipe size Stock 1991 - 1994 Explorers 2
G Oil leaking from behide the exhaust manifold bad thing? Stock 1991 - 1994 Explorers 1
C Exhaust system with a silencer of the Russian truck ! Video! Sound! Stock 1991 - 1994 Explorers 6
M Engine Tick or exhaust system? Stock 1991 - 1994 Explorers 8
S Exhaust Replacement on 1991 Explorer Stock 1991 - 1994 Explorers 7
X exhaust flange bolt stuck Stock 1991 - 1994 Explorers 5
P Exhaust pressure / Starting issue? Stock 1991 - 1994 Explorers 3
ld50 Gasoline from exhaust -FPR replacement Stock 1991 - 1994 Explorers 11
Number4 Exhaust manifold to pipe bolts Stock 1991 - 1994 Explorers 34
S Exhaust question Stock 1991 - 1994 Explorers 5
EMBRACETHEHATE89 exhaust leak Stock 1991 - 1994 Explorers 5
W Exhaust Leak Stock 1991 - 1994 Explorers 3
Number4 Getting to exhaust manif. nuts Stock 1991 - 1994 Explorers 12
K Terrible exhaust noise Stock 1991 - 1994 Explorers 2
L.A.X Ripped out my stock 1st Gen exhaust Stock 1991 - 1994 Explorers 5
R need urgent help with my exhaust Stock 1991 - 1994 Explorers 1
mr cribb new top end, now oil is blowing through the exhaust Stock 1991 - 1994 Explorers 25
mr cribb Horrendous exhaust odor Stock 1991 - 1994 Explorers 21
W Heads and Exhaust Bolts Stock 1991 - 1994 Explorers 13
W Dual Exhaust Stock 1991 - 1994 Explorers 15
A Exhaust Help!!! Stock 1991 - 1994 Explorers 4
Similar threads
