pony4896
- September 14, 2009
- Fayetteville, arkansas
- '92 Explorer 4x4
I believe that i have clogged cats? I was at the stoplight and i took off only to sputter out and soon couldnt make it go with any amount of pedal... I coast into a parkinglot and it completely died off and this smokey smell of sulfer just permiated the explorer. I tried restart 15 min later but it sounded like the exhuast was clogged and it started smelling like a Sulfer Fire again so i shut it down. Previous to this climax my check engine light was coming on and my gas milage was horrible ( about 6 miles to the gallon). Im thinking that i might have had a bad (fuel pressure regulator) but i dont know for sure. Would a bad fuel pressure regulator cause clogged convertors if Raw Fuel was being dumped into the engine and not being burned properly, thus causing tons of carbon to build up in the cats and clogging them up? ALso im broke (no money) and my explorer is sitting in that resturant parking lot probably gonna get towed to impound if i dont get it out soon. What would be a quick fix to get it to make it home? I would just cut the cats off and drive it home, but im concerned that with all that fuel dumping into the system, that it might be blowing it straight out the exhaust, thus causing straight-up fire to blow out that area were the cats would be cut-off. If i drive the thing without the cats/and the dumping fuel problem will i catch the vehicle on fire? Thanks, Jason
