The code is "P0420" - my book says that the code is " catalyst system efficency below threshold (bank 1)"
So does that mean i do need a new cat? or could it be something else? Thanks!
DO NOT REPLACE THE CAT JUST YET.
You may have failing oxygen sensors that are just above the performance level to give a code. A good scanner can determine that. I would reset the PCM, and see if the code comes back after a drive cycle.
The code is set because of a complex set of measurements and averages over time. It looks at an o2 sensor before and after the cat and sees the change in o2 activity. This is calculated with a weighted moving average over many miles and the light is lit after a certain threshold. The fix below makes the computer less strict as to when the code should be set.
If it still is an issue, and you have a 4.0OHV engine, take it to the dealer and have this addressed:
Article No.
00-26-4 MALFUNCTION INDICATOR LAMP (MIL) - MIL ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
Publication Date: DECEMBER 14, 2000
FORD: 1996 EXPLORER
This article is being republished in its entirety to update the Calibration Information.
ISSUE:
Some vehicles may exhibit a Malfunction Indicator Lamp (MIL) illumination along with a P0420 Diagnostic Trouble Code (DTC) stored in continuous memory with no driveability concerns. This may be caused by the calibration of the Powertrain Control Module (PCM).
ACTION:
If no other failures are observed during normal diagnosis, (physically damaged catalyst, stuck fuel injectors, etc.), reprogram the PCM with the latest level calibration in the application chart. PCM reprogramming should be performed before any emission hardware is replaced. If the vehicle already has the latest calibration, follow normal diagnostic procedures for DTC.
NOTE: PCM REPROGRAMMING SHOULD BE PERFORMED BEFORE ANY EMISSION HARDWARE IS REPLACED.
