Cb Radio
thebiggreen
Roanoke, Va
'93 Sport
so i got the radio and am in the process of getting an antenna, what is the best way to go about getting it installed?. can i install it and run the wires and just get the antenna tuned professionally, or should i get the wires run by profesesionals too? appreciate the help
peace
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Moved to "Ham Radio & CB - Trail Communications" sub-section
Mounty 09
Nothern IN
1997 Mountaineer
I make cb antenna mounts that go above your tail lights. $25 for one or $40 for a pair.
thebiggreen
Roanoke, Va
'93 Sport
thanks Mounty09 ill let ya know if i need the mounts. appreciate the quick response.
nolimitssjca
San Jose, CA
95 XLT, 96 XLT, 97 Mounty
Mounty you should post the pic of your bolt on design. That's really cool!
Mounty 09
Nothern IN
1997 Mountaineer
rizzjc
Scubajoe - Radio Mod
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
peace
If you buy a CB antenna and mount it per instructions, then I don't think you need to worry about tuning.
L4CX
East Lansing, MI
96 XLT
You actually should tune the antenna no matter how you install it. If you don't, you'll fry your radio. I still have to get mine tuned and I just put mine on. Here's a pic of my mount.
Mounty, do you have both those antenna's hooked up? I was just wondering what kind of reception you get? They look pretty cool.
xplorer490
nashville, north carolina
'95 xlt
how would you tune an antenna?
Mounty 09
Nothern IN
1997 Mountaineer
You tune your antenna with a swr meator. L4CX yes they are both hooked up but I dont get the best right now but that is also because I dont have very good cable on there. But I was talking to a friend on it and I would say he was a mile or two away.
xplorer490
'95 xlt
how did u get both those antennas hooked up to one cb?
Mounty 09
Nothern IN
1997 Mountaineer
Well the antennas that I bought came with a Y cable. But at radio shack I have seen a T conector.
rizzjc
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
So, it looks like you've got something like a K40 fiberglass. Exactly how do they tune those on the truck? I don't think they are going to cut it down ... or lengthen it, and that's the only way to tune it. An off-the-shelf antenna should not be so badly out of tune as to blow out your radio.
rizzjc
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
Well, I guess this answers my question:
http://www.firestik.com/Tech_Docs/Setting_SWR.htm
What do shops charge to tune your antenna? I'd love to see the SWR on an antenna "out of the box". I really expect that it would not be too bad, and I'd be REALLY surprised if it was bad enough to do any damage. I've never tuned a cb antenna before (and I've had several), and never had a problem. Only time I ever blew out a cb was when I accidentally GROUNDED the antenna.
Heck, I've got a ham radio, handheld dual-band, that I hook up to a home-made ground plane antenna that hangs from the ceiling. A friend brought his meter and checked the SWR on it one time and it was like 5:1, and I've been using this with no problems for YEARS.
Gator Jeff
Elite In Memoriam
2000 Sport 4x4
I've got a big Yakima rack that I have in place of the factory rack. I'm looking at mounting a pair of antennas the crossbars using mirror mounts.
A couple questions though...
1) Do I need to worry about grounding the antennas somehow? The Yak rack is obviously metal, but coated in plastic.
2) What is the best way to run the cables into my truck so that they don't bring the water with them? I'm assuming run them into the doors and along the seals, but at what point do I bring the cable into the inside of the truck?
Hopefully there isn't a thread out there for this that I missed, but if so, my apologies.
rizzjc
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
Grounding the ANTENNA would be bad. Grouding the antenna MOUNT is hopefully what you're referring to. Are these the old style mirror mounts that mount to a metal mirror frame? Maybe the set screw, or whatever, could be attached so that it contacts the cross-bar metal, through the plastic. However, if it is like my yakima rack, you are also insulated from the towers. You could check to see if the towers have a metal piece anywhere that has ground, and possible run a small wire to connect it to the antenna mount.
Gator Jeff
Elite In Memoriam
2000 Sport 4x4
Yeah, I definitely meant the MOUNT and not the antenna. My Yak is definitely insulated from the towers as well. I would definitely need a small ground wire then.
Knowing that, I may just bite the bullet and go with roof mounts since I'm also going to be installing a 2M/440 antenna and a scanner antenna at some point as well. If I was going with just a CB set-up, I'd definitely be using Mounty's sweet brackets. But, I don't care about holes in my roof since I plan on driving it until the wheels fall off. And even then, I'll just be on the forum figuring out how to put them back on!
Is there a good thread for dropping headliners?
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
I recently installed (< 2 months) a firestick II 4 ft antenna on the front bumper (front right, on a tab mount). Out of the box the swr (from what I can tell) wasn't too bad.. My SWR meter doesn't read 0 when off (it reads less than 0).. Judging by how far it moved when I tested it, I'd say my swr was right around 2.5. After tuning it, its down to almost nothing (meter barely moves on channel 1 and 19, and moves < 1 for channel 40)..
It is easy to tune.... My hardest part was getting the little rubber thing off, changing the length, then putting the rubber thing back on the tip (it has to be on when you check the swr)..
~Mark
rizzjc
Staff member
Moderator
Location
NC
Garner, NC
2019 F150
Callsign
N1LVN
Cool. Thanks for the info!
thebiggreen
Roanoke, Va
'93 Sport
thanks maniak, and all for that matter, this has been really heplful, i think im going with the firestik 4 or 5 ft, and gonna run it from the back bumper or just above the lights
appreciate all the help
peace
tdavis Interesting ham radio.. Ham Radio - CB - Trail Communications 9
K ham radio reccomendations Ham Radio - CB - Trail Communications 12
bigred4x4 Cb radio Ham Radio - CB - Trail Communications 0
R Entry Level Ham Radio help. Ham Radio - CB - Trail Communications 20
Rick New radio for the Pumpkin Yaesu FT400 Ham Radio - CB - Trail Communications 7
T 5th Generation (2015) Ham Radio Install Ham Radio - CB - Trail Communications 11
B cb radio/antenna help Ham Radio - CB - Trail Communications 3
T CB Radio and antenna install on a 3rd Generation Explorer Ham Radio - CB - Trail Communications 12
tdavis Getting Ham Radio for under $40.. Ham Radio - CB - Trail Communications 9
M In-dash CB Radio for a 01 Ranger fittings Ham Radio - CB - Trail Communications 2
LONO100 cb radio operation ettiquette and tips Ham Radio - CB - Trail Communications 27
LONO100 my first CB radio install (clean install, still working out bugs!) Ham Radio - CB - Trail Communications 39
M Sport Trac Radio install in High console Ham Radio - CB - Trail Communications 9
n.gardner Radio help... Ham Radio - CB - Trail Communications 6
M First CB Radio Suggestion Ham Radio - CB - Trail Communications 9
Tbars4 Man reaches astronauts with amateur radio Ham Radio - CB - Trail Communications 12
Keeper0311 Looking for advice on a good radio. Ham Radio - CB - Trail Communications 1
Elessar65 CB antenna in stock radio antenna location Ham Radio - CB - Trail Communications 3
justsomeguy Race Radio Question Ham Radio - CB - Trail Communications 9
S Power supply for radio Ham Radio - CB - Trail Communications 4
CobraMountaineer 2nd Gen Install Ham Radio Style Ham Radio - CB - Trail Communications 6
M Ford electronics vs. high power radio transmitters. Ham Radio - CB - Trail Communications 2
W Connecting CB radio to stereo? Ham Radio - CB - Trail Communications 4
S CB Radio Newb. Need Help. Ham Radio - CB - Trail Communications 10
Rick What's new in the ham radio world?? Ham Radio - CB - Trail Communications 3
I 10m radio on CB bands? Ham Radio - CB - Trail Communications 5
P Single DIN radio and CB in stock radio space Ham Radio - CB - Trail Communications 7
H 2006+ Radio Installs Ham Radio - CB - Trail Communications 14
big5dogg cb radio whats necessary? Ham Radio - CB - Trail Communications 44
Charlie CB radio and lightning Ham Radio - CB - Trail Communications 5
91exploreron37 Bad radio or connection? Ham Radio - CB - Trail Communications 13
Glen4X4 Need Expert Radio Advice Ham Radio - CB - Trail Communications 8
Raminator157 Fire Dept Radio Installation (Need Help/Suggestions) Ham Radio - CB - Trail Communications 24
M I got my new CB radio what do you think?... Ham Radio - CB - Trail Communications 7
2 cb radio Ham Radio - CB - Trail Communications 12
rizzjc Radio installations by Explorer model Ham Radio - CB - Trail Communications 0
rizzjc 3rd Gen Radio Installations Ham Radio - CB - Trail Communications 1
rizzjc 2nd Gen Radio Installations Ham Radio - CB - Trail Communications 64
rizzjc New radio opinions Ham Radio - CB - Trail Communications 14
9 Cb Radio Ham Radio - CB - Trail Communications 3
Rick Ham Radio Forum Moderator Needed Ham Radio - CB - Trail Communications 14
Lt.Jim 1st Gen Radio Installations Ham Radio - CB - Trail Communications 29
A Wheres a good spot to mount a radio Ham Radio - CB - Trail Communications 17
U What do you guy's think about this radio scanner? Ham Radio - CB - Trail Communications 7
B CB Radio & Antenna Ham Radio - CB - Trail Communications 22
C VHF Radio Install Write Up with pics Ham Radio - CB - Trail Communications 1
9 What is HAM radio and.. Ham Radio - CB - Trail Communications 2
C Radio Mounting Ham Radio - CB - Trail Communications 6
M cant get anyone on radio Ham Radio - CB - Trail Communications 4
B Handy 2-way radio installation tips Ham Radio - CB - Trail Communications 1
Similar threads
