there isn't a problem with the using the Rg-8 as power wire on low amp projects... just remember with a solid core wire, it can be more apt to breakage if you were to route it in such a way as to cause excessive vibration, or pulling, such as routed outside the cabin area, pulled between frame and body. It could service that way for months or years, but solid core wire won't last as long in that situation as twisted strand wires would.
I'd say its a cool idea, and worth looking into especially for ease of routing, if nothing else, just watch how you run it if its going through any flex points.
this would be true with your antenna's RG-8 so keep that in mind as well.
