Wyoguy222
- April 13, 2011
- Rapid City, SD
- '95 Ford Explorer
I have a 1995 Ford Explorer Expedition. Check Engine light has been coming on for years, and the bulb finally burned out about a year ago! Well I replaced the bulb today and finally use the wire trick to get my codes. Here is what I got the first time,
(KOEO) 111 327 631 327 631 1 327 327
So If I figure this right these are my codes
327-EGR feedback signal is/was low - EVR or PFE
631-Overdrive Cancel Light circuit problem - Transmissions
Here is codes for KOER
(KOER) 111 6327538536632116327538536632
And for this I figured these codes?
632-E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
753-I DONT KNOW
853-I DONT KNOW
663-I DONT KNOW
211-Ignition PIP signal was erratic or missing - Ignition Systems
Now I figured I don't have the right codes here because there is no such thing as the 3 above, so I redid it correctly I guess and got these codes for KOER
(KOER) 11 6327632116327632
So what codes would this be?!?
And my other question is, what does this mean? 631-Overdrive Cancel Light circuit problem - Transmissions
ALSO, after this was done I pressed the throttle to do that test, after that test was complete the CEL flashed 9 times, then 9 times again. What does that mean??
Which of these codes would keep my engine light on, it turns on after about 20 seconds of driving. My O/D light does not turn on at all, and might also be burned out, would that have anything to do with that code. I finally get all these codes and just don't know where to start! Anyone that can help me, I appreciate it! Thank you so much!
753-I DONT KNOW
853-I DONT KNOW
663-I DONT KNOW
