Center wheel cap finish bubbling- warranty item?
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
I recently noticed what looks like bubbling/degradation under the clear coat finish on all 4 of the center caps on my 2017 Exp Sport. On a previous vehicle I had a similar issue but it was moisture between the clear coat and the actual wheel, causing an unsightly bubbling on the actual wheel surface. Any one else experience this type of thing on their center caps? Would it be unreasonable to bring this up as a warranty item with the dealer? Vehicle has 27,500 miles on it, and carries the Ford ESP for 8 years as well.
seville009
2019 Explorer XLT
Not unreasonable to ask; still under warranty. Worst that can happen is they say “no”
KayGee
Farmington, MI
'16 & '17 PIU
It varies. Ask your dealer and if you don't like their answer, ask a different dealer. If it's just center caps, it shouldn't be a huge deal.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
It is covered under 3/36k. Esp will not cover it. Get it in under your b2b.
MM07
MA
2018 Explorer Limited
Had mine replaced on my 16 three times.
M Replacement Wheel Center Caps Stock 2011 - 2019 Ford Explorer Discussion 10
R Steering Wheel Off-Center Stock 2011 - 2019 Ford Explorer Discussion 23
L 18" XLT Wheel Center Bore Size Stock 2011 - 2019 Ford Explorer Discussion 9
R Looking for instructions for dismantling the center console Stock 2011 - 2019 Ford Explorer Discussion 2
F Broken center console latch Stock 2011 - 2019 Ford Explorer Discussion 3
Michael W Center AC Vent Vane Loose Stock 2011 - 2019 Ford Explorer Discussion 3
L Why the tiny "cup holder" in front center console? Stock 2011 - 2019 Ford Explorer Discussion 13
Jon M Center console lid loose Stock 2011 - 2019 Ford Explorer Discussion 5
S Flex Center Console in Explorer? Stock 2011 - 2019 Ford Explorer Discussion 8
J drive shaft center bearing Stock 2011 - 2019 Ford Explorer Discussion 3
C Center Console Airbag light and rear bucket seat positions Stock 2011 - 2019 Ford Explorer Discussion 3
T 2011 XLT Center Console Stock 2011 - 2019 Ford Explorer Discussion 0
T Looking for Center Console Change Cup Stock 2011 - 2019 Ford Explorer Discussion 4
O Tracing Plastic to Plastic rattle to the right center row of 2017 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 0
B 2015 Explorer Sport center console lighting issue Stock 2011 - 2019 Ford Explorer Discussion 1
B Adding a light to center console? Stock 2011 - 2019 Ford Explorer Discussion 3
N Center row overhead vent won't stay open Stock 2011 - 2019 Ford Explorer Discussion 2
P Rear Center Console Height Stock 2011 - 2019 Ford Explorer Discussion 4
Rainlord Probably a crazy idea, 2016+ center console on a 2011-2015? Stock 2011 - 2019 Ford Explorer Discussion 3
Eltee Power outlet on back of center console coming loose Stock 2011 - 2019 Ford Explorer Discussion 16
ExPlat Center Bezel cracked Stock 2011 - 2019 Ford Explorer Discussion 4
B Remove Center AC Vents Stock 2011 - 2019 Ford Explorer Discussion 2
G First experience at dealership service center Stock 2011 - 2019 Ford Explorer Discussion 17
M Can you add the center dash speaker? Stock 2011 - 2019 Ford Explorer Discussion 4
G 2013 front center console removal Stock 2011 - 2019 Ford Explorer Discussion 6
F Center Console access Stock 2011 - 2019 Ford Explorer Discussion 1
M Center console sensor/plug prohibiting vehicle from starting? Stock 2011 - 2019 Ford Explorer Discussion 1
B Which way does center console in rear open? Stock 2011 - 2019 Ford Explorer Discussion 2
S Center console noises?!?!?! Stock 2011 - 2019 Ford Explorer Discussion 9
J Edge sport center caps Stock 2011 - 2019 Ford Explorer Discussion 7
B 2013 explorer sport front center console removal ? Stock 2011 - 2019 Ford Explorer Discussion 3
M Center Pod Brightness Stock 2011 - 2019 Ford Explorer Discussion 4
J I'll buy your rear center console for $500 Stock 2011 - 2019 Ford Explorer Discussion 4
R Center console access Stock 2011 - 2019 Ford Explorer Discussion 3
F $37k Explorer - no center console on 2nd row? Stock 2011 - 2019 Ford Explorer Discussion 4
BobbyMarks Toggle switch inside A/V/Nav center console Stock 2011 - 2019 Ford Explorer Discussion 15
B Media center / MFT tip Stock 2011 - 2019 Ford Explorer Discussion 4
C Rear Center Console Stock 2011 - 2019 Ford Explorer Discussion 1
P Center Console Stock 2011 - 2019 Ford Explorer Discussion 1
B Center console passenger side lower panel Stock 2011 - 2019 Ford Explorer Discussion 2
R Media Center Light? Stock 2011 - 2019 Ford Explorer Discussion 8
R Center console trim problem Stock 2011 - 2019 Ford Explorer Discussion 3
J Just got a 2012 Ford Explorer Limited, LOVE IT! Missing center console on second row Stock 2011 - 2019 Ford Explorer Discussion 33
M Audio Video in Center Console Stock 2011 - 2019 Ford Explorer Discussion 6
M Does the media center support playing DVD's Stock 2011 - 2019 Ford Explorer Discussion 2
V Rear Center Console question Stock 2011 - 2019 Ford Explorer Discussion 6
jrgoffin Wheel bearings - very short lifespan. Stock 2011 - 2019 Ford Explorer Discussion 7
M Hello :) Ticking / Clicking noise heard when rotating steering wheel Stock 2011 - 2019 Ford Explorer Discussion 5
S What tire/wheel size are you running for winter tires? Stock 2011 - 2019 Ford Explorer Discussion 7
S Steering Wheel Power Tilt/Telescoping Function Not Working Stock 2011 - 2019 Ford Explorer Discussion 2
Similar threads
