Chain rattling noise | Ford Explorer Forums - Serious Explorations
Rodeo Joe
Elite Bostonian
Frankin, MA
1997 XLT
Lately when I'm driving on any kind of bumpy road, I'm hearing a noise underneath and the best way to describe is it sounds like there's a chain rattling! :confused:
I've looked and everything appears to be tight. I've heard this sound from other Explorers driving by, so is it a common problem?
I've tried search but only come up with timing chain rattles! :eek:
Joe
if its only on a bumpy road, id check the heat shielding around the cat converters. theyre prone to having a weld fail on them.
Also check under your skid plates if you have any. I tend to get rocks and junk up there but it comes from going 50mph down a dirt road! That will make a loose/rattle sound too.
check the sway bar end links, when they come loose it sounds like a chain is slapping the ground. Mine were really loose and even though i tightened them they still squeak a little.
Rodeo Joe- I am from Milford MA, right next door to you!
might check the dust shields on the brakes too. may want to check your front hubs too.:rolleyes:
