tkauf
- September 3, 2002
- Spokane, WA
- 94XLT, 94B4000, 91musgt
I have a 94 XLT which I bought 4 months ago with about 100/K miles. I have changed the oil twice in the last 4,500 miles (mostly highway). My pressure guage always runs about 2/3rd the way up the normal scale. Last weekend it had dropped to 1/3, was not a gradual drop, I just noticed it was running about 1/3 on the scale. I have a very slight noise from the engine and the level of oil is full. Now my question: I have heard other explorers with RTV silicone gasket problems. Little pieces of silicone in the oil clogging the pump screen. Does anyone have any experience with this. My plan is to change to 5/30 oil tonite (have been using Castrol 10/30) with a new filter of course. I intend to dump a quart of Kerosene in the motor with the drain plug out to hopefully flush the bottom of the pan. Is there any reason I can't do this? Also should I suspect my oil pressure sender as could be faulty? I have read other websites that claim you can drop the pan without disturbing the engine. My mechanic says you have to undo the motor mounts, disconnect the wiring harness and jack the motor up to get to the oil pump. Any comments, he wants $436.00; help!
