mxl4729
- April 20, 2010
- keyport, NJ
- 2003 explorer sport trac
So i bought a 2003 sport track a few months ago with 60,000 and want to make sure it is ready to last two 160,000 so i have started to change all the fluids.
the oil was black as black can be so i changed it ever 200 miles untill it came out clean. then put mobile 1 in it.
then i changed the transmission fluind by dropping the pan and changing the filter. then i removed the fluid return line and ran the motor as i dumped in more fluid until 24 quarts when thought it. then i added a transmission drain plug see post here ( http://www.explorerforum.com/forums/showthread.php?t=278945 )
drained the antifreeze filled with water. drained again and filled with distilled water and zerex g05 antifreeze
then i changed the brake fluid. had some one pump the brakes and kept opening the bleeder plug until i ran 4 bottles of break fluid through
next i moved on to the power steering fluid. removed the return line from the Power steering cooler. plug the hose going toing to the reservoir (all the fluid drains out when you pull the hose) filled the reservoir and started it while poring more power steering fluid in (ran 3 quarts through it)
So whats left for me to change???????????
Transfer case fluid ?
front and rear diff ?
anything i am missing?
from reading the form here i need a oil sucker to change the front diff. can anyone recommend a good one.
also how hard it is to change the transfer case fluid
