Changing to 20" wheels | Ford Explorer Forums - Serious Explorations
docksider
Atlanta
1992 XLT Pushrod
Will 245/45/20s rub
Planning to change to 20" inch wheels and concerned about the tires rubbing - I want to use 245x45x20 tires Does anyone know if these will rub?
245 is a bit narrow for the height of the tres...that is only 10mm wider than the stock 15" rubber...
I run 255 up front and 285 in the rear. No rubbing until full lock with suspension compression.
Ryan
