MaioCampo
- May 29, 2012
- 1993 Explorer
Hello,
Over the past month I've been chasing a coolant leak. I've had a shop look at it, but I've given up on them (just taking money I haven't got). So here is what I've got:
- Coolant leak from the front of the engine, in the neighborhood located behind the thermostat housing. It doesn't appear to be the housing, or the heater coil hose, nor does it appear to be the freeze plug located behind the A/C compressor and power steering.
- Coolant leak from the radiator cap. This just started in the past couple of weeks. I thought it was from the overflow hose, so zip-tied that, but then saw it coming from the cap. I replaced the cap, but I still have a slow, dripping leak.
- Coolant leak that appears to be coming from somewhere towards the back of the engine... maybe? While watching the front engine leak, which would make its way to the front of the front axle, I could hear a steady drip coming from behind the front axle. I don't think it is blowback... it dripped pretty steady long after the front leak stopped.
- Tonight I noticed milky white fluid on the radiator cap lip (just below the cap). Not milky green... milky white. It's a new radiator, I haven't used any sealant, so I'm not sure what that is. Oil looks fine. Fluid in the radiator is green as you please.
- No heat issues. The engine warms up nice, the gauge hangs around between the N and O, and straight up. Has never gone past straight up. I did have issues earlier in the year, but fixed those by replacing the radiator and thermostat.
- White smoke from the tailpipe, but only when cold. Once things are warmed up I don't really notice anything.
So I'm thinking about replacing the lower intake gasket. A friend wondered about heads, but I just don't see it... but I'm a hack. I'm sorry this is so long, but if you're still with me, what do you think?
