1997XLTRollover
- February 28, 2007
- 1996 AWD 5.0
Ok guys I'm kind of at a loss here and was just looking for some input. I don't want to just keep slinging parts at my truck to try to figure this out. So in a nut shell my truck shakes over 60 mph.
It feels like out of balance tires on the front but I don't think it is. I had brand new Goodyears on my stock wheels and now have a brand new set of 32's on Cragars and have the same shake. The steering wheel shakes ever so slightly but I think that's caused by whatever is shaking in the front end.
The shake feels like it's definitely in the front and I hear an ever so slight noise when turning left and right coming from the drivers front when in parking lots. I think it may be a wheel bearing that's getting old but I don't think that would cause a shake (correct me if I'm wrong) and the noise is very very quite not bad at all.
So far here's what I've done:
-New tires and wheels
-Front end alignment
-New sway bar endlinks and sway bar bushings
-New shocks
-New passenger side wheel bearing
-Checked for play in wheel bearings/ball joints and steering by pulling tire left/right/up/down feels tight.
-Ball joints all say Moog on them so I know they are not factory but I do not know when they were changed last
-Checked CV's and see no grease leaking, but I can move the axle shaft side to side (I think this play is normal, but again correct me if I'm wrong)
-Felt drive shafts for play and they also seem tight. I was thinking it could be the front drive shaft, but it feels like too heavy of a shake (it's not a vibration) to be a driveshaft I was going to pull this off and go for a drive but I feel like it's a waste of time.
-Swapped my rear drive shaft with a spare
-New shocks
