Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
- February 19, 1999
- Mount Vernon, WA
- 1st Gen XLT 4dr
- Callsign
- KG7VTT
I found a way to remove the front sway bar drop down brackets. The rear sway bar is useless due to the heighth of the superlift 5.5" lift. It's diameter does nothing for sway control but hinder off road articulation. If you use the supplied extended links from the rear, you can eliminate the front sway bar drop brackets that cause 33 inch tires to rub at full clock turning.
Here is how it works. Using what ever, I used a hack saw, cut the eye's off the rear extended sway bar links on the longer side away from the bends. Make a second cut measuring 3 1/4 inches in length. Reweld the eye back on, making sure to remove the bushings first, as close as possible to the edge of the eye creating the correct angle for the offset of the front sway bar and its mounting position on the axle. You will also have to grind about an eight to a quarter of an inch off the steel bushing insert to get the correct fit up front.
Next, simply remove the front sway bar drob brackets and the stock connecting links and reinstall the new ones. If you desire quick disconnects, see the thread on this site.
A little bit of hammer help had to go in to placing the lower ends in to the axle mounting points, but over time, I'm sure that will loosen up.
93XLT-5.5" Super Runner, Super Runner Steering, 1.5" Body lift,33x12.5,
Borla exhaust,KKM air filter
