I installed the new 9007 blue head light bulbs last night. Removed the battery and air box cover to get enough room and everything went pretty smoothly, EXCEPT for breaking those stinkin' little cheap plastic tabs off the left side electrical connector. Rats! I didn't move them more than 2-3mm max and they folded right up and broke off. There's probably enough friction in the connector to keep it from working loose (and causing the headlamp to quit). But in the event there's not, how tough is it to replace the connector? Does it splice into the wiring harness (unplug further upstream, hopefully)?
The worst part is...the Eurodezigns bulbs don't seem to put out as much light as the OE units. What did I do that for?
