Kevin_MichiganExplorer
- February 17, 2020
- Grand Rapids, MI
- 2012 Explorer Limited 4WD
Local Ford dealership identified the alternator bearings as the source of a sound I had been hearing on my Explorer with 100k miles, quoted $1200 to replace. That sounded like a lot so I picked up a remanufactured part from a local auto parts store that fits my vehicle. After the (long) process of swapping out the alternator and reconnecting everything, I am receiving a Check Charging System fault about 20 seconds after startup, although everything appeared to be running fine.
Took a short test drive down my street and back, and while driving, electronic assist systems progressively began shutting down: starting with the power steering assist (no fault or error message, but definitely no assist; turning the wheel was very heavy); collision avoidance system fault, brake assist fault, and SYNC went into "battery saver" mode and shut down the screen.
Is there something that has to be flashed in the computer to recognize the new alternator?
Have double checked the connections on everything and the pulley is spinning fine with no slipping. I'm at a loss.
