rileymutt
- March 31, 2014
- 1997 ford explorer
Hello all, new to the forum, but have been reading on here for a while. I have a 1997 Explorer with the 4.0l sohc. It has 53000 miles and I have a code that popped up. P0443 is the only code that was on the scanner. Took it to the dealer and they replaced the canister purge solenoid, but after about a week it came back. They say it could be the PCM but they are not sure. Are there any other components I should look at before I replce the PCM? The dealer says it is not available through Ford any longer, so if it is the PCM where would you folks recommend to get one? Thanks in advance for the help.
