Check Engine Flashing
ChrisMN1234
Mpls, MN
2014 Explorer XLT
All-
I recently bought a 2014 certified Explorer XLT with factory tow package at the local dealer. Everytime I tow our boat (the whole reason for buying it), the check engine light blinks when getting onto the expressway, we lose power and the air conditioning stops (only happens when towing).
Upon first bringing it to the dealer, they said nothing is wrong and gave it back. The second time we actually filmed the issue happening. This prompted them to replace some spark plugs and give it back. Now the issue is even worse and has nearly caused us to get into an accident while the family was heading to the lake.
Our dealer says to drive it in with the boat (over 30 miles of unsafe conditions) so they can give it a shot. Does this seem unreasonable to anyone else? Has anyone run into something similar and what did you do?
Ps- the car has also been in several other times with different varying issues that have been shrugged off by the dealer. Thoughts on how to approach?
Thanks!
-Chris
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
They weren't able to pull any codes, despite having the CEL flashing? Does it come on only when towing?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Chris.:wave:
As 613GT500 inquired, does this only happen when towing? It would also helpful, not just for this time, if you would add the 'trim' level (XLT) to your profile so it always shows in the margin. Not all trims have the same features. There are threads about throttle body issues which are similar to what you are experiencing.
There was another member who had A/C cut off under power but didn't mention the Check Engine Light. http://www.explorerforum.com/forums...rbo-4-cyl-no-a-c-when-its-hot-outside.446985/
ChrisMN1234
Mpls, MN
2014 Explorer XLT
As 613GT500 inquired, does this only happen when towing? It would also helpful, not just for this time, if you would add the 'trim' level (Base, XLT, etc.) to your profile so it always shows in the margin. Not all trims have the same features, including engines. Do you have the factory tow package?
I updated the original post with the requested info :). Trim is XLT with factory tow package. They've pulled codes for a cylinder 1 and 5 misfire but claim they can't fix without me bringing the boat trailer with.
-Chris
613GT500
Ontario, Canada
-Chris
Time to visit another dealership. A misfire trouble code
is more than enough to warrant a repair.
Flatplane
Location
Dallas metroplex
2016 XLT Explorer
I concur with 613GT500 dealership technician training level leaves too much off the table. Find a dealer that will do the right thing and fix ur car.
BMan5150
O-HI-O
2014 Ford Explorer Sport
Sounds more like your motor or transmission is overheating. I'm thinking the latter actually.
peterk9
Staff member
Moderator
Callsign
VE3
If there is an engine issue, I believe it will go into "limp" mode.
If the engine reaches a preset over-temperature condition, the engine
will automatically switch to alternating cylinder operation. Each disabled
cylinder acts as an air pump and cools the engine.
When this occurs the vehicle will still operate. However:
• The engine power will be limited.
• The air conditioning system will be disabled.
reserved50
2013 Sport Exploder
o_Omaybe ignition coils going bad?
Sixonemale
2015 XLT Appearance Pkg
CORRECTION: On my '02 Explorer it was my O/D light that flashed when the solenoid in the transmission was bad, not the CEL light.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
A flashing CEL that is giving a cylinder 1 and 5 misfire would not be transmission related. I'm thinking a bad coil pack as well and not just a spark plug. I've had bad coil packs on my audi and the same thing would result. Hard bucking, barely get it to move and CEL flashing.
If the CEL is flashing, it is a severe enough issue that you are not supposed to drive the vehicle (pull over and shut it off immediately).
Sixonemale
My bad, I semi glanced at the thread and did not read the misfire code that was pulled. The spark plugs and/or coil packs should be checked.
It should be noted that when I changed my spark plugs on my '02 way back when I replaced them with Motorcraft OEM plugs. I asked if they were pre-gaped and the parts store and Ford both said they were, unfortunately that was not the case. My engine ran horribly after replacing them and I had to take each one out, gap it to spec and reinstall each plug and then the engine ran normal again.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
How much does boat and trailer weigh? Are you using tow mode ? If this occurs again maybe try taking it out of tow mode or put it in if not using it.
Tow mode changes shift points and allows engine braking, that's all that Ford tells you. I wouldn't be surprised if there is a different fuel map/tune used for this mode as well.
ChrisMN1234
Mpls, MN
2014 Explorer XLT
I've tried it both with tow mode and not using tow mode, same issue (the boat weighs 3k pounds).
Also forgot to mention that the vehicle has less than 25k miles and they are pushing back because "Ford doesn't let us replace parts under warranty unless we can also duplicate the problem." I find that to be garbage since they've verified the problem codes.
Does anyone have a contact at Ford?
-Chris
sheltonfilms
Hoover, AL
2013 Limited 3.5L
-Chris
That's when you say you don't care what their internal "policy" is. The only thing you have to know is what is in your warranty documentation and that is what is legally binding.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
Have you tried flooring it without towing?
My train of thought is entering expressway=more throttle=higher rpm=more air /fuel.
Could have starving of either one. Clogged air filter/clogged fuel filter or even fuel pump that can't keep up.
peterk9
Staff member
Moderator
Callsign
VE3
Chris, does this same issue exist when NOT towing?
Flatplane
Location
Dallas metroplex
2016 XLT Explorer
Flashing Ck Eng light with misfire codes will disable the a/c compressor to prevent excessive damage as a result of misfires. That strategy is written into the PCM software P0301 P0305 would be misfire codes. EcoBoost engines need spark plugs changed sooner than the recommended interval due to plug wear and excessive gaps causing the misfires. Continued misfires can damage the ign coils as result of misfires. Misfire codes are considered emission faults and so covered by the warranty.
gatzdon
IL
2000 Exp XLS 4WD V6 OHV
Not that you should have to do this, but I would get a Bluetooth OBD adapter (that can read MS-CAN) and Forscan Lite.
You can pull the DTC's from all modules including the PCM and related modules when the condition is happening. Forscan Lite will allow you to export the DTC's with freeze frame data. You could even email them to yourself when they occur.
Many dealers will ignore your data when you bring the vehicle in, but you have already said that it happens multiple times and they are unable to duplicate. Time to document the issue yourself and escalate. If nothing else, the freeze frame data should help a knowledgeable technician duplicate your situation.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Are these coil on plug or do they use a coil pack? either way, cylinder 1 and 5 are "companion" cylinders, meaning they both fire at the same time on a waste spark system. Either an ignition control module ( if it is present) PCM or coilpack issue is my gut feeling.
You might escalate this to the ford customer service rep on board our forum. Good luck!
G 2019 XLT 3.5L NA - Flashing Check Engine P0300, P0305, P0306 Stock 2011 - 2019 Ford Explorer Discussion 9
J Check Engine warning under acceleration Stock 2011 - 2019 Ford Explorer Discussion 10
M Check Charging System/Engine Light Stock 2011 - 2019 Ford Explorer Discussion 2
M Engine Dies and Check Engine LIght Stock 2011 - 2019 Ford Explorer Discussion 4
H 2013 Explorer Limited - Check Engine Light Stock 2011 - 2019 Ford Explorer Discussion 3
B 2017 Explorer Platinum recall and subsequent "Check Engine" light Stock 2011 - 2019 Ford Explorer Discussion 2
K Check engine light 2016 eco-boost Stock 2011 - 2019 Ford Explorer Discussion 16
A Check Engine Codes 2013 Explorer, P0138, P2096 Stock 2011 - 2019 Ford Explorer Discussion 6
N 2011 ford explorer check engine light Stock 2011 - 2019 Ford Explorer Discussion 16
F 2012 XLT is unresponsive after check engine light Stock 2011 - 2019 Ford Explorer Discussion 1
S Seriously check engine light?!!! Stock 2011 - 2019 Ford Explorer Discussion 7
P Coolant check Stock 2011 - 2019 Ford Explorer Discussion 8
T Do I really need to check the transmission fluid level after I change it? Stock 2011 - 2019 Ford Explorer Discussion 21
R Check Charging System Frustration! Stock 2011 - 2019 Ford Explorer Discussion 7
S 2012 Explorer ABS light, Hill Descent, , Terrain Management, Check Brake System Stock 2011 - 2019 Ford Explorer Discussion 10
K Check Charging System after installing new alternator Stock 2011 - 2019 Ford Explorer Discussion 27
C 2013 check charging system fault Stock 2011 - 2019 Ford Explorer Discussion 11
R Check Brake System, Service AdvanceTrac and Collision Warning Malfunction Stock 2011 - 2019 Ford Explorer Discussion 26
M Price check: 2018 Sport with 401A Stock 2011 - 2019 Ford Explorer Discussion 17
T Check Charging System Warning Stock 2011 - 2019 Ford Explorer Discussion 6
L Check Charging light and NO a/c, No cooling fans, No radio? Stock 2011 - 2019 Ford Explorer Discussion 12
A 2015 Explorer Sport - Check Charging System Stock 2011 - 2019 Ford Explorer Discussion 7
Daheim111 Check AT fluid level / what is the way to do this correct ? Stock 2011 - 2019 Ford Explorer Discussion 4
K Rear Parking Sensor Problem: "Check Rear Park Aid" Stock 2011 - 2019 Ford Explorer Discussion 3
S 2017 Owners - Can you please check the bolts that secure your hood>>> Stock 2011 - 2019 Ford Explorer Discussion 5
M 2011 Explorer "check charging system" Stock 2011 - 2019 Ford Explorer Discussion 19
L Check this Navigator concept Stock 2011 - 2019 Ford Explorer Discussion 2
1 System check question Stock 2011 - 2019 Ford Explorer Discussion 1
E Can someone check their rear view mirror wires? Stock 2011 - 2019 Ford Explorer Discussion 5
P Can any dealer check my VIN and see what was replaced throughout the life of my car? Stock 2011 - 2019 Ford Explorer Discussion 0
C Service AdvanceTract, Check Brake System and Hill Descent Control Fault Stock 2011 - 2019 Ford Explorer Discussion 6
S P2196 and P2198...what to check Stock 2011 - 2019 Ford Explorer Discussion 35
J "Check rear sensors" Stock 2011 - 2019 Ford Explorer Discussion 12
L Check fuel inlet Stock 2011 - 2019 Ford Explorer Discussion 15
peterk9 Does your Explorer Have An Outstanding Recall? Check Here Stock 2011 - 2019 Ford Explorer Discussion 0
A Price check for 2014 New Explorer sport with 401A option Stock 2011 - 2019 Ford Explorer Discussion 7
B 2014 New Owners - Check Your Wheels when you pick up your new ride.. Stock 2011 - 2019 Ford Explorer Discussion 52
H "Check Fuel Fill Inlet" light Stock 2011 - 2019 Ford Explorer Discussion 4
F ABS Self Check? Stock 2011 - 2019 Ford Explorer Discussion 1
E 2013 Owners (Sport would be nice) - Need you to check something for me.... Stock 2011 - 2019 Ford Explorer Discussion 11
M 10 Things to Check on a New Explorer Before Taking Delivery Stock 2011 - 2019 Ford Explorer Discussion 2
S Check Brake System Stock 2011 - 2019 Ford Explorer Discussion 12
C lost systems check since update. Stock 2011 - 2019 Ford Explorer Discussion 7
B TSB? check .... Stock 2011 - 2019 Ford Explorer Discussion 5
C Picking up my explorer today, what should I check? Stock 2011 - 2019 Ford Explorer Discussion 16
H Check out this screen. Stock 2011 - 2019 Ford Explorer Discussion 7
J List of Useful Threads Hints for a Pre-Pick Up Inspection & Used Ex. Check List Stock 2011 - 2019 Ford Explorer Discussion 24
S P219f engine code Stock 2011 - 2019 Ford Explorer Discussion 1
E Random RPMs drop, engine seems want to stall Stock 2011 - 2019 Ford Explorer Discussion 2
D Starter engages after engine start Stock 2011 - 2019 Ford Explorer Discussion 3
Similar threads
