#$%$ Check Engine Light - Code 332 | Ford Explorer - Ford Ranger Forums - Serious Explorations
tshaner
Goddard, Kansas
1994 Limited
Here we go again....
I'm getting that darn Check Engine Light again...
Codes show 332, no other symptoms...
Here is what I have done:
1) Cleaned out all passages of carbon builduo
2) Replaced EGR Valve & Gasket
3) Replaced PFE (DPFE) Sensor & associated vacuum lines - two of them
I'm out of ideas.... Any help?
'94 Exp. Limited
TPLYNCH
Brewster, NY
1999 XLS
Did you disconnect the battery to reset the computer after you replaced those items?
tshaner
Goddard, Kansas
1994 Limited
I did not disconnect the battery, but I did clear the codes using the scanner. I might try the battery though, just in case...
