Check Engine Light - What do these codes mean? | Ford Explorer Forums - Serious Explorations
NJExplorerFan
New Jersey
2015 Limited
I'm trying to figure out what codes I currently have pending on my '97 SOHC 4.0L V6 Explorer. I ran a scan a few moments ago and came up with the following 2 codes:
P0420 - Catalyst Efficiency Below Threshold, Bank 1
P0430 - Catalyst Efficiency Below Threshold, Bank 2
Any idea what this could mean? I thought maybe I needed a new catalytic converter, but maybe it's something else? How can I narrow this down as to my exact problem? Are there any other scanners out there that can break this down further (ie. Ford dealer)?
Turdle has a couple good threads on that here.
His suggestion was to switch the back o2 sensors, reset the computer and see if it throws a code again for the opposite side. If it does you know the sensor is bad.
