Check Engine Light
DASEXPLORER
Arlington, TX
2016 & 2020 Limited 4WD
The light came on tonight while driving. Looked at the Ford Pass information and it indicated Malfunction Indicator Lamp - Regulatory
I find nothing in the manual about this.
Any ideas?
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Any ideas?
You profile says a 2016 Explorer but you posted in the 6th gen (2020) forum. Which do you have?
  • Like
Reactions: imp
DASEXPLORER
Arlington, TX
I need to change my profile, I have both a 2016 & 2020 Limited.
My recent posts have been about the 2020.
Along with today’s issue, the 2020 was in the shop most of last week due to a check engine light from last Saturday that limited the vehicle power and only allowed 2nd gear. The dealership found 2 codes: 1116 & 2243, neither were active but had been stored. The vehicle only has 500 miles and I’ve now had 2 events.
I’m not feeling very good about the 2020 limited so far. Never had any issues like this with the 2016 limited.
DASEXPLORER
Arlington, TX
Started the 2020 this morning Check Engine Light still on; however the vehicle does start and run, so whatever the problem, it's not critical.
Log In to my Ford account to see if this event had been logged and found an 1 Issue. It doesn't give as much detail as the phone app. I assume this information is available to dealerships, so if I call the dealership that worked on the explorer last week, they can access this information.
The Ford Pass web site as an area that says "Let's get to work", however it's had the spinning oval for the last 30 minutes, so we're not getting much work done.
Woah322
SI,NY
17 Sport
20 XLT
No resolution or fix yet ?
DASEXPLORER
Arlington, TX
I’d hoped so, the dealership had the vehicle for a couple days last week. They were not able to reproduce the fault (the check engine light cleared after a couple of days). The solution was to reflash the program and hope for the best.
Today, the check engine light came on again, ran the vehicle health report from Ford Pass and got the same message “Malfunction Indicator Lamp - Regulatory”. No clue as to what this means, the dealership from last couldn’t give me an answer, so I guess I’m back nearly to stage 1.
I sent a text message to my service rep with the latest and ask to have their technical service manager call me tomorrow.
Woah322
SI,NY
17 Sport
20 XLT
Yea the FordPass will only indicate a general message for check engine light but you need to get the actual code pulled to know what the problem is. Go to advance auto or autozone and they check it for free if you don’t own your own scanner.
Exphab
Irvine
2020, Explorer Limited 4w
Was the issue fixed? Did it happen again? I just got my explorer on 1st and today same issue happened. I will take it to dealer tomorrow.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
^^ Welcome to the Forum. :wave:
hbalek
Kensington, MD
2020 Ford Explorer ST
This happened to me at around 2200 miles, the dealer checked it out and found nothing. It had gone off after a few hours and hasn't happened since now at over 3000 miles.
Exphab
Irvine
I haven't driven 300 miles yet.
Exphab
Irvine
I wanted to give an update. Vehicle was driving fine this morning but check-engine light was still on. Dealership said that it just needed a program reset. The codes that were given: P062C and P2243. Also, they said that they have seen a few cars with similar problem and Ford has sent them instructions to perform certain resets if the issue occurs.
