Check out this suspension setup - 1 link w/ panhard bar
Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
This is a strangely easy but very functional looking suspension. Combined with some coil overs it looks like it would work really well and be cheap with regular coils and affordable with coil overs.
Scroll down about half way and look for the blue Scout.
http://www.pirate4x4.com/forum/showthread.php?t=273512&page=2&pp=30
Here's my questions.
1. Of course what would be the pro's and cons of a setup like this?
2. How would you figure out the appropriate angles, lengths, etc.?
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 XL '16 XLT
That's pretty cool. I wish there was a better picture of the joint at the driveshaft. It look like it moves from side to side a bit. That thing mite be a little scary on the street though. :(
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Looks pretty cool. All of the forces are put through the pivot ball. That's the only weakness I can see. Carry a spare and you're good to go. I think one of the guys on this site built an Ex with 'mog or Volvo portal axles and he used a similar rear suspension.
As far as the construction is concerned, that's not my thing so I can't help you with that one.
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
There aren't any pics on that page. At least not for me...
everythintech
Lynnwood, Wa
'98 XLT
wow, i dont know a lot about suspension styles, but that flex is crazy! kinda just what i want. I just might be doing a lil more research up on that style, seems a lil more mind intensive, but a lot less harware intensive. i like that a lot.
redranger4.0
Salem CT
2000 Ranger XLT
its a one link with a grader ball. the grader ball is like 200 dollars. theres a couple guys on pirate running a graderball. non have broken yet. they are really strong. 034x4 is going to run a rear onelink. i am going to also but not untill i get my shit done
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
The beauty of it is that is less mind intensive as well. You can start all the fabrication by simply removing the gas tank, keeping the axle centered with the leaf springs and fab everything in place. Then simply add coils, or if you really want to, coil overs, then remove the leafs and your dour done, excepth for relocating the gas tank of course.
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
For Rick
standard
standard
standard
standard
standard
standard
standard
kert0307
Pella, Iowa
'00 Sport and '89 B2
I tried a setup like that for the rear of a full suspension go-cart a built in high school. I ended up bending it doing some high speed(well more like 35mph) cornering during some testing, but at slow speeds and rock crawling I think it'd be ok
FROADER
Staff member
Moderator
Huntington Beach, CA
1991 Eddie
That was greenmeanie, but he hasn't updated for a very long time. I even posted asking for updates a couple weeks ago and nothing.
FROADER
Staff member
Moderator
1991 Eddie
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Looks like a pretty simple setup to build. Tons of flex too :cool:
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
Looks like I found another advantage. Instant skid plate mounting that is clear of other moving things.
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Anyone know?
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
So far from what I have read here http://www.pirate4x4.com/forum/showthread.php?t=235977 is that ublike a four link where the figures change as the suspension cycles, with this set up your numbers stay the same. It seem most that use this type put the link right below the transfer case side of the driveshaft. Some even have the tubing bolted in place of the leaf spings. The more I look at the designs of this, the easier it gets.
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
FROADER said:
Do it Kevin! Do it...do it...
I am still planning. First is coil overs on top of the ford radius arms up front. The I tackle the rear. I am not looking for drivability since it is a trailer queen now, just looking for stable off roading characteristics.
I probably will do it though :D
tdavis
Linux Guru, Jack of All Trades
Staff member
Admin
Pinole, CA
2001 F250/XLT Superduty
Callsign
KG6MAX
So, here's some questions for you:
1) What does it do to the roll center of the vehicle? Raise it, lower it, or keep the same? Vehicle roll center is the tendency to "roll" when turning. The zuk has more of it now, but at the same time that allows it to eat up bumps like it never did before. A high roll center means less roll, but a rougher ride at speed.
2) Does it roll steer any at all, and if so, does it bother you? Roll steer could be painful - in a turn, it will try to straighten you out instead of turning.
3) Is it a neutral, squat, or anti squat in the rear when you goose the gas? A high-anti squat rear could be good for hill climbs, but get it too high and suddenly the rear will start to hop. Hopping is bad - that is what destroys drive shafts, and breaks axle shafts.
Diff Whack Daddy
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
See question 2 in the first post of this thread. I are stupid and don't have nuf brain cap for that. So far I haven't found anyone else who has figured that out either. I think it will actually cause an anti-squat being mounte just below the t-case rear u-joint.
I already roll steer and fight the hell out of it on the road, what little it sees. For the simplicity and cost, it would be worth a try just to see what happens.
