Check Your PCM! And Related Connections
Banjoes
Florida
1995 Ford Explorer XLT
Thanks to Scotty Kilmer on YouTube for being my inspiration on making this how to for mechanical noobs like me, plus I want to thank the forum for saving a lot of money on fixing my Explorer myself-where I'm confident enough of course.
Well I went and unplugged my PCM (after disconnecting battery) and found out it was dirty on the inside, no corrosion, just covered in dirt.
[/URL][/IMG]Anyway this is where the PCM is located on a 1995 XLT 2WD.
First, disconnect battery:
[/URL][/IMG]
Second, get appropiate socket wrench and loosen until the connector comes out:
[/URL] [/IMG] DO NOT TOUCH PINS THEY MAY BE WEAK!
Third, get some electronic cleaner:
[/URL][/IMG]
Fourth, clean these areas:
[/URL] [/IMG]
Fifth disconnect and clean these areas too:
reinstall in reverse order and you are done!, make sure you DRY THE PARTS FOR ABOUT A HALF HOUR BEFORE YOU PUT IT BACK TOGETHER!
